Im trying to create a template that will allow me to automatically generate a marterial and material thickness in the title block based on the part that had been applied to the drawings. for example all of our work and drawings are usually sheet metal so i create the drawing in a flat patern and i want the title block to generate a meterial thickness so our supplier knows what material we need and the the material grade for example 304 or 316 stainless steel.
i was hoping to get a title block that would generate a field that would read as Material: 1.5mm 304 2B S/S
does anyone know if this is possible and what i need to link it to.
also i have used custom material so that the ANSI304 material is labeled as 304 2B S/S so i already have my materials described the way that i want them
Matthew
