Hi
I have just startet with a side(top view) that i jave extruded (NanoCopter.SLDPRT), but the extruded cut for the other sides seems not give a good result.
The body should be hollow with a 0.8mm wall thickness (most of the time). The 4 motor-mounts should be 1.5mm plate thick.
After extruding the top view, how can i go further? Any help would be greatly appreciated
thank's a lot
Andy
Ramseier, I simply copy and pasted your dxf drawing profiles onto sketches in the SW model and made cuts. I had to cut the bolt pads off, then shell the model. Once shelled, I added the bolt pads. I think my attached model should help you achieve what you are looking for. Chad
