HI all,
im trying to use previously drawn blocks in Draft Site in models in Solidworks.
I have linked the file locations to my library folder and the come up, but if i try to drag them into a model or a drawing i get loads of other artifacts pulled in.
If i mouse over the item its shows up as the part.
and this is what i get if i drop it into the model or drawing.
Is it because they are DWG images and need to be converted?
just need a bit of guidence on this please.
Thanks in advance.
Ok i need to convert from dwg to sldblk.
I was thinking about trying to use the solidworks task scheduler to convert dwgs to sketches, then try creating a macro to convert them to blocks.
I cant get the task scheduler to work , it opens the DWG then savea a DWG, err and SLDprt file but the sld file is empty?
Any ideas please.
