VPVincent Piazza10/07/2013
I have a macro that exports the mass properties of all of the parts in and assembly to excel. It seems to work alright on all of the parts, except those that do not have any mass properties. For those parts, they get the mass properties of the top most assembly. Is there a way I can ignore these parts which don't have any mass properties?
Here's a snippet of the code:
Sub SwExtractData()
Dim swApp As ISldWorks
Dim swModel As IModelDoc2
Dim swModExt As IModelDocExtension
Dim swAssembly As IAssemblyDoc
Dim swComp As IComponent2
Dim MassProp As IMassProperty
Dim Component As Variant
Dim Components As Variant
Dim Bodies As Variant
Dim BodyInfo As Variant
Dim CenOfM As Variant
Dim RetBool As Boolean
Dim RetVal As Long
Dim Description As String
'Get active drawing view
Set swModel = swApp.ActiveDoc
Set swAssembly = swModel
Set swModExt = swModel.Extension
Set MassProp = swModExt.CreateMassProperty
'Open Excel
OutputPath = Environ("USERPROFILE") & "\Desktop\"
OutputFN = swModel.GetTitle & ".xlsx"
Set xlApp = Excel.Application
xlApp.Visible = True
Set xlWorkBooks = Excel.Workbooks
Set xlBook = xlWorkBooks.Add()
Set xlsheet = xlBook.Worksheets("Sheet1")
'Populate Excel Spreadsheet Titles
xlsheet.Range("A1").value = "Type"
xlsheet.Range("B1").value = "Part"
xlsheet.Range("C1").value = "Description"
xlsheet.Range("D1").value = "Material"
xlsheet.Range("E1").value = "Volume"
xlsheet.Range("F1").value = "Surface Area"
xlsheet.Range("G1").value = ""
xlsheet.Range("H1").value = ""
xlsheet.Range("I1").value = "Weight"
'Set current row to 2
xlCurRow = 2
RetVal = swAssembly.ResolveAllLightWeightComponents(False)
Components = swAssembly.GetComponents(False)
On Error Resume Next
'Loop that populates excel spreadsheet
For Each Component In Components
    Set swComp = Component
        If swComp.GetSuppression <> 0 And Not swComp.IsHidden(False) Then
            Dim swModelComp As SldWorks.ModelDoc2
            Set swModelComp = swComp.GetModelDoc
            If swModelComp.GetType = swDocASSEMBLY Then
                Set MassProp = swModelComp.Extension.CreateMassProperty
            Else
            MassProp.UseSystemUnits = False 'Use document units
            Bodies = swComp.GetBodies2(swSolidBody And swSheetBody)
            RetBool = MassProp.AddBodies(Bodies)
            CenOfM = MassProp.CenterOfMass
            xlsheet.Range("B" & xlCurRow).value = swcomp.GetPathName
            xlsheet.Range("C" & xlCurRow).value = GetRefConfigProps(swComp, "Description")
            xlsheet.Range("D" & xlCurRow).value = GetDefaultPartProps(swComp, "Material")
            xlsheet.Range("E" & xlCurRow).value = Round(MassProp.Volume, 2)
            xlsheet.Range("F" & xlCurRow).value = Round(MassProp.SurfaceArea, 2)
            xlsheet.Range("I" & xlCurRow).value = Round(MassProp.Mass, 5)
            xlsheet.Range("K" & xlCurRow).value = Round(CenOfM(1), 5)
            xlsheet.Range("M" & xlCurRow).value = Round(CenOfM(2), 5)
            xlsheet.Range("P" & xlCurRow).value = Round(-(CenOfM(0)), 5)
        'Tests to see if last three letters in file name are asm or prt
            If LCase(Right(swComp.GetPathName, 3)) = "asm" Then
                    xlsheet.Range("A" & xlCurRow).value = "Assembly"
                ElseIf LCase(Right(swComp.GetPathName, 3)) = "prt" Then
                    xlsheet.Range("A" & xlCurRow).value = "Part"
                Else
                    xlsheet.Range("A" & xlCurRow).value = "ERROR IN MASS PROPS OUTPUT"
            End If 'Right 3 of file extension
    xlCurRow = xlCurRow + 1
Next Component
xlsheet.UsedRange.EntireColumn.AutoFit
