This is very hard to explain but I will try my best...
How do I change column Number on Library Components if I have configuration on it and it's included in assembly? This is when you right click on a assembly in the Vault (Workgroup PDM) and show Document Information and select References and select Config: Default [in use] SW will not change column Number to right number that I have in specific configuration.
When I use the BOM-list in the drawing it takes correct number that I have configured.
See picture below
That's just a custom property called "Number". If you want it to reflect different values for different configurations of its parent component, you'll need to open that file, and set the value for each configurtation in the custom properties dialog box or in a design table.
