3 Replies Latest reply on Jul 10, 2013 7:39 AM by Artem Taturevych
    SldDrw File Converter to Adobe PDF is Error?
    Yong Ning
      Follow Programe Code is PrintFileName is empty
         SwModel.Extension.PrintOut2 vPageArray, 1, True, SwDraw.Printer, ""
      result is
      Manually select the output file PDF file,see picture
      if Programe code is PrintFileNmae not Empty
         SwModel.Extension.PrintOut2 vPageArray, 1, True, SwDraw.Printer, PrintFileName
      Programe  Error  is
      When you create the postscript file, you have to send the main font. Please go to the printer properties "AdobepDF settings" page and deselect the "don't send fonts to Distiller" option
      My target is Auto Print Adodb Pdf file.
      Thanks .
      the programe code is
      Sub lll1()
      Dim SwDraw As DrawingDoc, SwModel As ModelDoc2
      Set SwModel = Application.SldWorks.ActiveDoc
      Set SwDraw = SwModel 'Application.SldWorks.ActiveDoc
          PdfName = Split(SwDraw.GetTitle, " - ")(0)
          FileName = SwDraw.GetPathName
          PrintFileName = Left(FileName, InStr(FileName, "SwHG20592") + 8) & "\PDF\" & PdfName & ".Pdf"
          Debug.Print PrintFileName
      Dim Ps As PageSetup
         Set Ps = SwDraw.PageSetup
         Ps.Orientation = 2   ' 1=Portrait  '2 = Landscape
      Dim pageArray(3) As Long
         pageArray(0) = 1: pageArray(1) = 1:
         pageArray(2) = 1: pageArray(3) = SwDraw.GetSheetCount
      Dim vPageArray As Variant
         vPageArray = pageArray
      Programe  Error  is
      当您创建postscript文件时,您不得不发送主字体。请跳到打印机属性的“AdobepDF设置“页面并取消选择”不要发送字体到Distiller"选项
