Does anyone know of a way automate exporting the x,y coordinates of points in a sketch straight to excel? I can interrogate each sketch point manually, however this will be very long winded.
James
James
No direct way. If you know how to write macros you can write a macro...
If you have a whole bunch in one sketch, you can use the sketch as the driver for a sketch driven pattern and create holes in a dummy part. You can then put the part in a drawing and create a hole table which can be exported.
