Hi all,
I am trying to execute a macro within an Excel spreadsheet from within a SW VBA macro.
The spreadsheet consists of various thread data, major pitch and minor diameter information, along with the capability to calculate 3 wire size information as well.
The macro in the spreadsheet allows the user to select the thread form they desire, the size of the thread, and if they want 3 wire size inspection information as well.
Once they select this information, it is then pasted into the active drawing within SW as a table.
This part works quite well...
The next part is where I am having a few issues.
I would like to have a custom macro button available to the operator from within SW so that the operator does not have to open Excel Spreadsheet and run the program from there.
The process I would like to have the macro follow is thus:
1. Check to make sure a drawing document is active.
2. Create a new instance of Excel
3. Open the required spreadsheet.
4. Run the "Display_Thread_Form" subroutine within the spreadsheet macros
5. Close the Spreadsheet instance, leaving any other instance of Excel intact.
6. Return to SW displaying the previously active drawing.
So far points 1,2 & 3 are working.
Point 4 is not working at all using the method shown in the code below.
Point 5 works also but if I use xlApp.quit it closes the entire Excel Application down, so any other spreadsheet that may happen to be open is also closed.
If I enable the TASKKILL process then Excel is definitely shut down!
Point 6...? I always end up with not returning to SW! How do I get back there?
The code:
Dim xlApp As Excel.Application
Dim xlWB As Excel.Workbook
Dim ActiveDocName As String
Dim longstatus As Long
Dim vFileType As Variant
'Link to Solidworks
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then
MsgBox "No document loaded" & vbCrLf & _
"Open a Solidworks Drawing first!", vbMsgBoxSetForeground + vbSystemModal
Else
'check the type of Open document to make sure it is a Drawing file.
vFileType = swModel.GetType
If vFileType = swDocDRAWING Then
ActiveDocName = swModel.GetTitle
'Create a link to a NEW instance of Excel
Set xlApp = CreateObject("Excel.application")
'Make sure instance is visible
xlApp.Visible = True
'Open the target Excel Spreadsheet
Set xlWB = xlApp.Workbooks.Open("C:\Threads\Threads.xls")
'Run the macro using the passed in name
xlWB.Application.Run Display_thread_form
'Close the active workbook, do not save changes.
xlWB.Close False
'Close the Excel Application
'xlApp.Quit
'activate the drawing again.
swApp.ActivateDoc2 ActiveDocName, False, longstatus
'Clear memory
Set xlApp = Nothing
Set xlWB = Nothing
'Kill off any Excel Process that may be still running
'Shell "TASKKILL /F /IM Excel.exe", vbHide
I am hoping that someone will be able to help and I thank you in advance!
Regards
Brian.
