Hi all!
I am attempting to model a simple air flow channel. In my application, oxygen diffuses out through the roof of the channel. I want to observe the change in mass fraction of oxygen down the length of the channel.
I have set this up in the following way:
Inlet face: mass flow rate inlet, Oxygen and Nitrogen with substance concentration set to 0.22 Oxygen and 0.78 Nitrogen volume fractions.
Roof: mass flow rate outlet, Oxygen only (using substance concentrations of 1 Oxygen and 0 Nitrogen)
Outlet face: static pressure opening, set to atmospheric pressure.
When I run the model, using a cut plot along the length of the channel there is no change in the mass fraction of Oxygen or Nitrogen, regardless of the inlet/outlet mass flow rates.
Does anyone have any suggestions as to why I am not observing a gradient in the mass fraction of Oxygen along the length of the channel?
What you have defined by your roof is that whatever exits goes into a pure Oxygen atmosphere. Not that only the Oxygen exits. I would have to think if there is a way to do what you are thinking...
