Is there a way to turn on the right click menu while searching? I'm not actually in the search tool, but just using a search.
While in the vault you can right click on the white space and create a new document or use a template. Usually while I am using a search I find an issue with a file in the vault and would like to use one of our right click templates to track the problem. But I have to navigate to back out of the search to do this. Not a big issue but I would like to know if there is way to turn on the right click menu while searching.
Thanks!
If you add "Can administrate Users" under administrative permission,
you can customize your mouse buttons by clicking in the search window next to Tools.
as admin you can edit you admin card, but it can be ok for the user to have this option.
