8 Replies Latest reply on Jun 29, 2013 5:34 PM by Michael Caulton
    List type custom property change problem
    Michael Caulton
      Image "SW Model View"
      I have a problem were I cannont update a custom properties on the right side of the picture that are drop down lists, such as property "Material Form" (Variable name "MaterialForm-2013"). They are lists style custom properties with custom values allowed, so if one clicks in the box one can enter any text one wants or select a value from the drop down list.
      Image "SW Custom Properties View"
      This shows the custom properties and thier variable names.
      Below is the code I have used to try and edit the custom properties.
      • It works for "Thisckness-2013"
      • It does not work for "MaterialForm-2013"
      Does anyone know how I can get it to work on the lists style properties?
      SW 2010 X64 SP5.0
      Set swModel = swApp.ActiveDoc
      Set swConfig = swModel.ConfigurationManager.ActiveConfiguration
      Set swCustPropMgr = swConfig.CustomPropertyManager
      ' Set custom Properties
          swCustPropMgr.Set "MaterialForm-2013", "Profile"
          swCustPropMgr.Set "Thickness-2013", Chr(34) & "Thickness@Sheet-Metal1@" & swModel.GetTitle & ".SLDPRT" & Chr(34) & "mm"
      swModel.ForceRebuild3 True
