2 Replies Latest reply on Jun 27, 2013 3:50 PM by Cory Lehr
    Complete SolidWorks Transparency
    Cory Lehr
      First off I'm not sure if this is the correct location for this, if not let me know where I should direct this question.
      Has anybody ever experienced SolidWorks turning completely transparent to where you can see through to your desktop and still work on what you have open?  Whenever I try to use 3d sketch inside a model my entire session of SW will turn transparent.  I also found out that it will turn transparent when I use the drop down menu in a drawing to create a BOM.  I am running on windows 7 64-bit with an NVidia quadro 2000 video card.  I'm on SW2013 SP03.  Also whenever I mark a dimension in a drawing to driven it will re-size my window (usually split on two monitors) to be a little window in the top left of my home screen.  I have submitted a request to my VAR for this but thought I would also check here.
      Any help is appreciated.
      Cory
