Hi All
Ran into something while dimensioning in an angled reference plane. While dimensioning the sketch, the dimensions are obviously using projected references onto the plane. Does anyone know how to add say a vertical dimension with a sketch on an angled plane. Im using a work around by creating a reference point sketch defined veritcally on the angle and then coincident my next sketch to that point.
***Added image for reference. If you see the 70mm from the top of the cone, I am wanting that to be 70mm vertical with the global y-axis, not 70 along the reference plane***
Will this approach work for you?
