I was working on a part when all of a sudden the display style started acting up. I attached a picture with what it looks like. Right now, I am in a part environment with the display style set to "Shaded with edges." The display is orthogonal. When I change the display to perspective everything is fine. I attached some photos of what is going on. I have tried the following:
https://forum.solidworks.com/message/215989#216026
Ajay,
You have a topological error in your model. Go to Tools>Options>System Options>Performance. The first checkbox is for "verification on rebuild". Turn that on, then hit CTRL-Q. This will do a full force rebuild, and it will probably turn some of your features RED. Those need to be analysed for why they are bad (causing inverted faces).
Make sure to turn verification on rebuild back off after you get it all fixed. It very significantly increases rebuild time, so you don't want it on all the time.
Here is an example of me doing this on purpose: https://forum.solidworks.com/message/68019#68019
However, it only helped a little and none of my features are red. Does anyone have a solution?
Other useful information:
Solidworks Office Premium 2010 x64 Edition
Computer:
Operating System: Windows 7 Enterprise 64-bit (6.1, Build 7601) Service Pack 1
RAM: 4 GB
Graphics:
Card name: Intel(R) HD Graphics Family (Sorry, I can't find any more specific information on it. dxdiag doesn't even give me the exact info.)
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
DDI Version: 10.1
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Manufacturer: Intel
Card: Intel(R) HD Graphics Family
Driver: 8.15.10.2476
Your current graphics card/driver combination is not in the SolidWorks systems/graphics card database.
Card/driver combination information can be found at: http://www.solidworks.com/pages/services/VideoCardTesting.html
More information available upon request
This seems like a video card or driver issue. You need to find out your video card and look up to see if it is approved and or get the approved drivers for it.
