Hi all, I am listing a few things below that I have come across in the current version of SW 2013 SP3 Simulation, please comment if you have found a work-around or solution to any of them?
- The symbols for loads and fixtures are very temperamental, they show now and then, sometimes one of two loads shows, sometimes fixtures don't show and I have no idea why? They are not hidden and the symbols are turned on, as some of the symbols still come up.
- The current config sometimes jumps, unprompted, between the default and exploded configurations.
- When editing the values of a thermal resistance contact or the gap clearance of a no pen contact, a remesh is forced and apparently this wasn't always the case?
- Switching between different configurations sometimes causes the mesh to be out of date, even when returning to the correct configuration.
- I have no idea what the "An element type is not available for Elastic Support #"?
Lastly, is there a way to set the default type for the result plot "Save as" option to .JPEG?
Thanks!
>seen this but it has basically always come down to me using the show/hide command and forgetting about it.
>haven't seen this. if it is exploded it shows exploded, if it isn't, it doesn't. could it be that when you switch to probe everything collapses?
>those seem like reasonable reasons for a remesh to happen. (haven't tested or been exposed to it before though) when wasn't it the case?
>seen this, almost always it is because something is being rebuilt which is the trigger
>seen this, almost always been a bad setup or bad mesh.
>what is the default on your system? i don't think this is possible. check the simulation options. generally i use the snipping tool in simulation to create my screenshots.
my suggestion would be to get examples of each of these, package them up, and send them off to your reseller. but make sure to check they aren't already existing issues in the solidworks KB
