Hi everyone,
I am currently working on a project to analyze a syringe. The outlet is the needle and there is no inlet.The plunger will move and the liquid in the barrel will flow out of the needle into "environment" with certain pressure. What we are intersted in is the force exerted on the plunger and the oulet pressure.
Does Solidworks Flow simulation provide such boundary conditions and allow a plundge move and push the liquid?
Thank you very much
as soon as you use the word "move", it is likely outside the realm of what flow simulation can do. you need a moving mesh for those types of problems.
the second thing is that you need 2 phase flow (fluid into water)
are you sure this needs to be simulated? is there something unique about this problem that there are no closed form solutions?
