Circular Pattern w/ Sweep
Discussion created by Guest on Jun 6, 2006
Hi, I'm using Solidworks 2005 and i'm trying to apply a circular pattern to a sweep. (I'm making a grill for a fan). For some reason when I do the circular pattern, even though the preview will show up, the final rebuild doesn't show any change. Its like its done nothing, there are no rebuild errors or options wrong. All sketches are fully defined. It doesn't work if I try and just mirror the sweep feature.
When I try to apply a circular pattern to a simple box extrude (jus to test it) it says that "Some feature instances are disjoint and will not be created. Use the Bodies option to mirror/pattern distinct bodies."
You can see the file I'm working with if you rename the attachment to "GRILL.SLDPRT"
