Gross weight shown in a BOM column
Question asked by Vinicius Pontes on Jun 24, 2013
Latest reply on Jun 25, 2013 by Vinicius Pontes
I need to show the gross weight of a part in a BOM column. If I associate the column property with "SW-Mass@Part1.SLDPRT", it gives me the net weight.
I've tried to create a Global Variable called "GROSS_WEIGHT", which calculetes the gross weigth based on a simple equation which refers to the part dimensions. It seems to work until you close the drawing and re-open it. Solidworks doesn't evaluate the global variables when the drawing is opened, so, instead of the gross weight value, I see the string "GROSS_WEIGHT@Part1.SLDPRT" in my BOM.
Is there any solution for this? It should be simple. Most of the companies I've worked uses the gross weight in BOM.
Thanks in advance for any kind of suggestion.
Vinicius
