Following is my solution. I didn't read the Eng-tips faqs
' Go to "Tools --> References" and look for something like "Microsoft Excel xx.xx Object Library".
' Set All SolidWorks References as well!
Option Explicit
Dim swEnt As SldWorks.Entity
Dim swFace2 As SldWorks.Face2
Dim vTessTriangles As Variant
Dim vBodies As Variant
Dim swBody As SldWorks.Body2
Dim exApp As Excel.Application
Dim sheet As Excel.Worksheet
Set exApp = New Excel.Application
If Not exApp Is Nothing Then
exApp.Visible = True
exApp.Workbooks.Add
Set sheet = exApp.ActiveSheet
If Not sheet Is Nothing Then
sheet.Cells(1, 2).Value = "X1"
sheet.Cells(1, 3).Value = "Y1"
sheet.Cells(1, 4).Value = "Z1"
sheet.Cells(1, 5).Value = "X2"
sheet.Cells(1, 6).Value = "Y2"
sheet.Cells(1, 7).Value = "Z2"
sheet.Cells(1, 8).Value = "X3"
sheet.Cells(1, 9).Value = "Y3"
sheet.Cells(1, 10).Value = "Z3"
Set swModel = swApp.ActiveDoc
Set swPart = swModel
vBodies = swPart.GetBodies2(swSolidBody, False)
Set swBody = vBodies(0)
Set swFace2 = swBody.GetFirstFace
Dim i As Long
Dim row As Long
row = 2
'i = 1
Do While Not swFace2 Is Nothing
vTessTriangles = swFace2.getTessTriangles(False)
For i = LBound(vTessTriangles) To UBound(vTessTriangles) / (1 * 9) - 1
sheet.Cells(row, 2).Value = (vTessTriangles(9 * i + 0))
sheet.Cells(row, 3).Value = (vTessTriangles(9 * i + 1))
sheet.Cells(row, 4).Value = (vTessTriangles(9 * i + 2))
sheet.Cells(row, 5).Value = (vTessTriangles(9 * i + 3))
sheet.Cells(row, 6).Value = (vTessTriangles(9 * i + 4))
sheet.Cells(row, 7).Value = (vTessTriangles(9 * i + 5))
sheet.Cells(row, 8).Value = (vTessTriangles(9 * i + 6))
sheet.Cells(row, 9).Value = (vTessTriangles(9 * i + 7))
sheet.Cells(row, 10).Value = (vTessTriangles(9 * i + 8))
row = row + 1
exApp.Columns.AutoFit
Next i
Set swFace2 = swFace2.GetNextFace
Loop
Option Explicit
exApp.Workbooks.Add
Dim i As Long
Dim row As Long
row = 2
'i = 1
row = row + 1
Next i
Loop
Thanks in advance. (Below is my first attempt)
Option Explicit
'Set swSelData = swSelMgr.CreateSelectData
'Set swFace2 = swSelMgr.GetSelectedObject5(1)
swModel.ClearSelection2 True
Dim i As Long
i = 1
' Select through Entity
'bRet = swEnt.Select4(True, swSelData): Debug.Assert bRet
Debug.Print "(" + _
Str(vTessTriangles(9 * i + 0)) + "," + _
Str(vTessTriangles(9 * i + 1)) + "," + _
Str(vTessTriangles(9 * i + 2)) + ")"
Debug.Print "(" + _
Str(vTessTriangles(9 * i + 3)) + "," + _
Str(vTessTriangles(9 * i + 4)) + "," + _
Str(vTessTriangles(9 * i + 5)) + ")"
Debug.Print "(" + _
Str(vTessTriangles(9 * i + 6)) + "," + _
Str(vTessTriangles(9 * i + 7)) + "," + _
Str(vTessTriangles(9 * i + 8)) + ")"
i = i + 1
Loop
