I have assigned faces on a component with appearances. These faces show various different colours.
When I import the Assembly that contains said component, the faces are NOT seperate entities any longer and I cannot add materials to individual faces.
This is very frustrating as it worked perfectly well with SW2012SP5.
Any help would be appreciated.
Have you tried add appearances at part level? Using Appearances at Assembly level does not give one enough control over said faces, this is because part level overrides assembly level.
