Start journey with SW, it is fun.
I need to offset below surface by 1.5mm (inside), but it give me a failure and ask to try smaller distance. I thought it should be able to do...please help
Hi Lin,
Offsetting surfaces can be problematic due to the surface construction, radius of curvature and what you're offsetting and whether it can geometrical extend and knit the new surface back together. Can you post your example, otherwise I'm afraid I can not help you without seeing the issue in SW.
Regards
Mark
Opps, attached the wrong photo. see this..
