I am building an assembly where I want to create a coincident mate between a construction axis of a cylindrical part to a construction plane and am not having much luck. Can't see why I can not do this, but am not having much luck.
I created both the construction axis and plane in the assembly, and therefore was not part dependent. I assumed that creating construction planes and axis fell to the part level. Bad assumption....
Hi Alan,
You should be able to mate these two together, but clearly there is more to this. If you would like to upload the file I will be happy to have a look.
Best regards,
Ben
