3 Replies Latest reply on Jan 21, 2015 5:25 PM by Yong Ning
    How to hide dimension?
    Yong Ning
      Set SwDim = .Parameter(Ss)
      My question
        How to Hide dimension → SwDim → Hide Dimension
      Thanks.
      Sub ll1()
        Dim Arr(7)
          Arr(0) = "PipeTHK@FlangeSketch@ee.Part"
          'Arr(1) = "D@FlangeSketch@ee.Part"
          Arr(2) = "Fd@FlangeSketch@ee.Part"
          Arr(3) = "A1AB@FlangeSketch@ee.Part"
          Arr(4) = "NAB@FlangeSketch@ee.Part"
          Arr(5) = "L@CutHoleSketch@ee.Part"
          'Arr(6) = "K@CutHoleSketch@ee.Part"
          Arr(7) = "D1@Alfa基准面@ee.Part"
        Dim ii, jj
        Dim SwApp As SldWorks.SldWorks, SwDraw As DrawingDoc, SwModel As ModelDoc2
        Set SwApp = Application.SldWorks
        Set SwDraw = SwApp.ActiveDoc
        Dim vSheets, SwSheet As Sheet, SwView As View, SwDim As Dimension
        Dim Ss
        With SwDraw
          vSheets = .GetSheetNames
          For ii = 0 To 0 'UBound(vSheets)
            .ActivateSheet vSheets(ii)
            Set SwSheet = .GetCurrentSheet
            For jj = 0 To UBound(Arr)
              If Not IsEmpty(Arr(jj)) Then
                Set SwDim = .Parameter(Arr(jj))
                Debug.Print jj, "Need Hide → ", SwDim.FullName
            Next jj
          Next ii
        End With
      Result is
      0            Need Hide →  PipeTHK@FlangeSketch@ee.Part
      2            Need Hide →  Fd@FlangeSketch@ee.Part
      3            Need Hide →  A1AB@FlangeSketch@ee.Part
      4            Need Hide →  NAB@FlangeSketch@ee.Part
      5            Need Hide →  L@CutHoleSketch@ee.Part
      7            Need Hide →  D1@Alfa基准面@ee.Part
        • Re: How to hide dimension?
          Simon Turner
          You actually need to access the DisplayDimension object rather than Dimension.
          Something like this:
          boolstatus = swModel.Extension.SelectByID2("PipeTHK@FlangeSketch@ee-1@Drawing View1", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
          swModel.HideDimension
          swModel.ClearSelection2 True
              Yong Ning
              Thanks your tips
              SwDraw.Extension.SelectByID2→Select Dimension to  Highlight → Hide dimension → don't show dimension.
              Hope Set Swdim function → hide dimension → return Show dimension.
              Sub ll1()
                Dim Arr(7)
                  Arr(0) = "PipeTHK@FlangeSketch"
                  'Arr(1) = "D@FlangeSketch"
                  Arr(2) = "Fd@FlangeSketch"
                  Arr(3) = "A1AB@FlangeSketch"
                  Arr(4) = "NAB@FlangeSketch"
                  Arr(5) = "L@CutHoleSketch"
                  'Arr(6) = "K@CutHoleSketch"
                  Arr(7) = "D1@Alfa基准面"
                Dim ii, jj
                Dim Str As String, tmp
                With SwDraw
                        Str = Arr(jj) & "@" & .GetTitle & "@v1"
                        Debug.Print Str
                        tmp = SwDraw.Extension.SelectByID2(Str, "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
                        .HideDimension
                    Next jj
                  Next ii
                End With
                  Yong Ning
                  Private Sub del20150119()
                     Dim Xls As Excel.Application, Rng As Range
                        Set Xls = GetObject(, "Excel.Application")
                        Set Rng = Xls.Selection
                        Set Rng = Rng.CurrentRegion
                     Dim RegExp As New RegExp, Str As String
                        For ii = 1 To Rng.Rows.Count
                           Str = Str & Rng(ii, 1) & "|"
                        Next ii
                        RegExp.Pattern = Left(Str, Len(Str) - 1)
                     Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
                        Set SwModel = SwApp.ActiveDoc
                     Dim SwSelMgr As SelectionMgr, SwLayerMgr As LayerMgr
                        Set SwSelMgr = SwModel.SelectionManager
                        Set SwLayerMgr = SwModel.GetLayerManager
                        SwLayerMgr.SetCurrentLayer "尺寸线"
                     Dim SwDraw As DrawingDoc, vSheet, SwView As View
                        Set SwDraw = SwModel
                        vSheet = SwDraw.GetSheetNames
                        For ii = 0 To UBound(vSheet)
                           SwDraw.ActivateSheet vSheet(ii)
                           Set SwView = SwDraw.GetFirstView
                           Set SwView = SwView.GetNextView
                           Do While Not SwView Is Nothing
                                 RegExpDelDim SwModel, SwView, RegExp
                           Loop
                        Next ii
                  Function RegExpDelDim(SwModel As ModelDoc2, SwView As View, RegExp As RegExp)
                     Dim SwDispDim As DisplayDimension, SwDim As Dimension, SwAnn As Annotation
                        Set SwDispDim = SwView.GetFirstDisplayDimension
                        Do While Not SwDispDim Is Nothing
                           Set SwDim = SwDispDim.GetDimension
                           'Debug.Print SwDim.FullName
                           If RegExp.Test(SwDim.FullName) = False Then
                              Set SwAnn = SwDispDim.GetAnnotation
                              SwAnn.Select True
                           Set SwDispDim = SwDispDim.GetNext
                        Loop
                        SwModel.EditDelete
                  End Function
