The tool bar you see in this picture below the file folders has disappeared and I can not get it back. Tried to remove and restore the vault view and than unloaded and reloaded EPDM. Still nothing. Running windows 7 ????? So far the Var was not able to help but they are still working on it.
Problem solved. Had to unistall remove the Reg files and reinstall. Did the unistall without removing the reg files and that did not work. Had to do a clean sweep.
