3 Replies Latest reply on Jun 14, 2013 2:17 PM by Kevin Berni
    CSWP Sample Initial Part Mass Question
    Jesse Vanderhoff
      I'm prepping for the CSWP exam and I can't seem to get the correct value for the sample part presented. This is for the intial part and I end up with a mass of Mass = 14666.46 grams when the answer is 14207.34 grams. I have double checked the work and cannot see where the problem lies. My only thought is that there may be a problem with the 15mm offset sketch as you can see it peaking though the cylinders even though the cut should be smooth.
      Thanks in advance for the help.
