KBKevin Bouwman12/06/2013
I am new to Electrical and am finding I need to add most of my parts to the library. I have currently run stuck trying to figure out how to add solenoid valves to the library. My current project contains an SMC SY5000 series six valve manifold. One valve is a 4-way, 5-port, 3-position, w/block ports when centered. It has two 24VDC solenoid coils. The other 5 valves are 4-way, 5-port, 2-position, spring return, w/one 24VDC solenoid coil. I would like to create schematics for the electrical and for the pneumatic circuits so these parts would have circuit connections for both. I often use such a manifold configuration but with different combinations of valves. Have any of you delt with this in any way? If so, how?
Thanks!
