We are using edrawings for assemblers to use for reference in our assembly area. We make custom machinery using many levels of subassemblies. Edrawings will not display the latest version of a part in an assembly unless the assembly gets checked out. Most of the time our assemblers are working with the top level assembly. This would require engineering checking many levels of assemblies out many times in order for them to see the change. Has anyone else had this issue and is there a solution for this? Thanks
since edrawing just views 3D data that is saved to the assembly file, and doesn't actually look at the part files, I do not see a way around creating a new version of the top level when ever you wanted to see the changes in edrawings.
