We are using solidworks 2009 with sp1(100 user license). The license file is in the server with dongel. Now we want to change the server with new server without dongel.
I came to know for solidworks dongel is not required . I tried removing the dongel from the current(old) server, once you remove the dongel solidworks not working.
Any suggestions.
Thanks.
Ganesh
Ganesh,
I hope you kept good relations with your VAR, because you will probably need to talk with them to work out what you can do. I don't remember when the switch was made to not requiring a dongle, but I assume, since you have a dongle, that it was after 2009. My guess is that you are stuck; the version you are running requires a dongle. Your choices would be to update to a later version that doesn't require a dongle or switch to a server that allows a dongle. But I know almost nothing about the subject, so I'm quite likely wrong.
Jerry S.
