Hi!
Ins't possible to weld 2 parts with fillet bead in assembly mode?
I really need to use fillet bead due structural requeriments
Hope my solidworks have that funcionality disable
Hi!
This changed a few years ago it used to create an incontext component in around version 2010 this was replaced by the new weld bead tool (assembly features -> Weld Bead) which gives a graphical representation, plus details can be added for the symbol and even material/ weight under the weld folder.
Why is it that you needed it to be physical geometry?
The best solution i can think of if you need it to be a physical object is to manually create an incontext part with a sweep and subtract to get the geometry you are after.
Alan
Alan
