I'm running into a problem where the weld beads in my assembly are not displaying at all. When the assembly is first being loaded it displays all the welds where they are put in but then dissapears as if they are hidden after the assembly finishes loading and all that is associated with the weld is a streight line. I think the problem would have to be related to the document or system properties since it recognizes it at first but then dissapear.
Check that "Weld beads" is active in your "View" menu.
