Hello, I have a sketch with a lot of lines and symbols in it, when I try to fully define the sketch I currently have to pull on lines and points to see if they are under defined as the whole sketch is black.
Is there any way to see what is still under defined, I know there is a "degrees of freedom" option in Inventor so I was hoping something similar exists in SW, I don't want to use the auto define option because I want to be in control of things.
The simplest way is to have seperate colors. The default setting for sketch entity colors is black for fully defined and blue for under-defined. If that's been changed, you can set it to whatever colors you want at Tools > Options > System Options > Colors > Color scheme settings.
