1 Reply Latest reply on Jun 3, 2013 9:47 AM by Dwight Livingston
    Adding to Circular Center Mark Pattern
    Nate Decker
      Is there a way to add to an existing circular center mark pattern? I've added another hole to the pattern and would like to dimension the angle from center. When I put in the new centermark it is vert/horz by default. I know I can manually rotate the centermark but that wouldnt update correctly. I had to delete the current centermarks and start over just to add in the new instance.
