I have a drawing with 9 sheets. the first sheet is the full assembly and than addition sheets have parts or section views. i updated a part which is on this drawing. Sheet one of the drawing shows the part got updated and is in the assembly on sheet one. sheet 4 which has the same part with dimensions did not get updated. this is the break down.
part 63030528-01_side_c gets updated to 63030528-01_side_d
drawing 63030528-01D
sheet 1 view10 got updated (from 63030528-01_side_c to 63030528-01_side_d)
sheet 4, view 52 has 63030528-01_side_c dimensioned. it did not get updated to 63030528-01_side_d which has new dimensions.
how can I get sheet 4 to update to the new revision?
thank you for your help.
Linda,
Does your file name for the part actually change? If so, then you need to change the references for the part drawing. Normally than would be done by going to File/Open, selecting your drawing, selecting the "References" button, and then choosing the new part. I assume it works the same for a multi-sheet drawing with both assemblies and parts.
This is not a very good way to run SolidWorks.
Jerry S.
