Hey,
I am trying to create a mold for a part (fan) I imported as a .igs file. I created the parting line, parting surface, but get an error when tring to use the Tooling Split fuction, the error reads: "cannot knit sheets together". Here are some images of the part and the process I have taken so far. I assume the promblem is due to the shape of the parting surface as it moves between the blades, but I can't seem to make the surface and simpler.
Parting Line.
Parting Surface, gives a strange surface that crosses over itself between the blades of the fan.
Note: the resulting Parting Surface between at the top left and bottom right of the image.
This is the error I then recieve when trying to use Tooling Split
I have included the part file.
Any assistance would be greatly appreciated!
Rod Mathaus,
Welcome to the forum
You may have to create the parting surface manually,
Please see this demo from Alin
Hope this helps
