Hole Callout on Externally Referenced Parts/Bodies
Question asked by David Chiles on May 22, 2013
Latest reply on May 31, 2013 by Matt Rohr
Can a hole callout be used on a hole wizard hole from an externally referencd part/body?  I have a weldment that has sub-weldments with tapped holes.  The detail drawing of the subweldment will only give geometry dimensions and not the tapped hole spec (tap size and depth) when using the hole callout command.  Is there a way to link the hole callout from the weldment to the subweldment detail drawing?
