Why is it that the latest version of an assembly in the EPDM add in and in the search tool are not the same. Even after I clear my cache they come up the same as in the attached screenshot. From what I can tell the Bronze bushings in the assembly should not even show up when open in Solidworks.
Justin,
Ah that probably explains what happened. When he used the pack and go the bushing was probably bundled with it and he dumped it along with the main part into a folder and checked it in. Then either you had the "Don't allow files with duplicate names" option turned on so he couldn't check in the bushing or he checked in the bushing and realized he didn't need it and deleted it. So when you open it in SolidWorks it uses the search routine to find a matching part in the vault so it shows up in the add-in, but there is no reference in the database because either the bushing never got checked in or the one it was referencing got deleted. If you check out the assembly and check it back in you should resolve this issue.
