How to use "Add Parameter" ??
Question asked by Chris Michalski on May 21, 2013
Latest reply on May 21, 2013 by Jerry Steiger
Okay, I'll be the first to admit I'm more adept at Flow than Simulation, so...
I would like to define a new parameter for post-processing.  In a series of simulations I have either tension or compression but rarely any shear.  So instead of using a separate P1 and P3 plot I'd like to make a parameter that is P1+P3.  Not intensity (P1-P3) because that always gives you a postive value, I want to be able to see whether it is tensile or compressive.
So I go to "Add Parameter" and try to input this.  But I can't find a list of the built-in variables you are allowed to use.  All I want to do is P1+P3.  Should be easy enough.
Hints or suggestions?
