I have an assembly that is demonstrating some interesting behavior when it comes to moving a part. An identical part moves freely. A review of the mates on each has not helped me to understand this behavior. Given the following photo:
I find that I can freely move the slide circled in blue. However, the one circled in red will move momentarily and then stop. I can "grab" it again and move it a bit more, but then it will once again stop responding to mouse movement. Seems to be time related - that is, if I move fast, I can move farther, but if I move slowly, then not very far before it locks up.
The part in red is the part marked "6823_linear bearing<1>" in the FMDT. The part marked in blue is "6823_linear_bearing<6>" in the FMDT. The others are fully defined.
Thanks in advance,
That is weird. I'm seeing the same glitch happening as well. I was able to move the Width Mate "Width5" to component 6823_linear_bearing<5>, and that seemed to get rid of the glitch.
No idea what is causing it, but I would suggest sending the files to your VAR so that they can forward it to the SW techs.
