I need to share a 3D model with a third party, but do not want to send the full details of assembly/part files.
I would like to save my parent assembly to a read-only, graphical data only type of 3D format.
What format do you suggest?
I tried WRL so far but it was creating a HUGE file, so I ended the process before it completed. I also tried HCG, and although SW seemed to be able to export to HCG, I couldn't then import it back into SW. I believe CRG files are for Catia only.
Thanks for your help.
Well, edrawings works pretty good and gives the best visual fidelity without providing goemetry. From there, the person you're sending it to can export it to STL if they want to bring it into Max or Blender or something
You can write the files straight to STL-which most programs can read in.
