Hi all,
I serched the archives, but the search terms here are pretty general and return a gazillion hits. So I'll just ask...
Is there a way to select a component in an assembly via geometry? I know I can select a face or feature on screen (click once to select a face, click tweice to select a feature) and the component will highlight in the tree - then I can pick the component in the tree and perform a component operation... I just was hoping there was a way to select the component directly from the screen.
-Nate
Nathan,
As Ian says, you can copy & paste fairly quickly. Once you have copied your material you can right click any where on the part & select paste, a quick menu pops up & you can choose to apply it to the face, feature, body, part or assembly. This method is fairly quick if you are able to see the parts easily & they are not hidden. The other thing you could try that might work for you is to try to select the parts from the Display Manager & the appearance tab. If you know what material they already have you can just select that & apply a new material.
