Problem using IEdmTemplate53::RunEx
Question asked by Brian Dalton on May 17, 2013
Latest reply on May 17, 2013 by Brian Dalton
I'm trying to use this command to run a template and get the path to the file created by it.  I can use the IEdmTemplate::Run command successfully, but this one won't even compile because the VS2008 IDE complains that it doesn't recognize the constants called out in the code.
I am using code straight out of the API reference and I made sure to declare the template object as type IEdmTemplate53.  I have no idea why the IDE complains that these things aren't declared.  There's no declaration for them in the example code in the API reference... What am I missing?
This image shows the highlighted references that VB2008 can't recognize.  If these things aren't included in the EdmLib, where are they?
