Hello everyone,
since the update to EPDM 2012 and SWX 2012 we have a problem. On occasion generating a SWX File, especially drawings, leads to a local File, which then has to be added to the vault manually, which is not intended. Especially because most of the time the person saving a file does not get an information, that the file was not added to the vault. When our sales departement is looking for drawing we notice there is none on the server so we have to look for local files on our Workstations and add it manually to the vault.
If I had to guess I would say this happens every 30-40th drawing and is happening on all of our 4 systems.
Has anyone had the same experience or even better does know a solution?
Kind regards
Phillip
Phillip,
Do you use "save as" pretty often? I know that save as can cause this problem occasionally.
