Re: Corrupt Macro
Deepak Gupta May 14, 2013 1:21 PM (in response to Brian Mick)The macro is opening fine. Can you open it in editor?
I've attached the codes in a text file.
SaveAsPDF_backup.txt.zip 2.2 KB
Re: Corrupt Macro
Brian Mick May 14, 2013 2:53 PM (in response to Deepak Gupta)Deepak,
It works great. I have no idea what was corrupting it. Thank you.
Brian
Re: Corrupt Macro
Cory McHale May 15, 2013 9:12 AM (in response to Brian Mick)I've ran into this also, and the only fix I've found is to open and resave the file on our older machine that has SW2012. After that I'm able to edit and run it in SW2013. I wish I understood why.
Re: Corrupt Macro
Brian Mick May 15, 2013 9:16 AM (in response to Cory McHale)Cory,
Thanks for the input. I have no idea what corrupted the macro, or what is different on Deepak's computer that let him open it just fine. I couldn't even open the file in the editor - it would crash every time.
Thanks for the input about SW2012 - we upgraded all our machines together, so I don't have access to 2012 anymore, but it's interesting that the macro appears uncorrupt in the older version. Perhaps it has something to do with the fact that I wrote it in 2012? (But I have edited it many times using SW2013 before this sudden corruption).
Re: Corrupt Macro
Cory McHale May 15, 2013 9:50 AM (in response to Brian Mick)Yeah, I'm lucky our old laptop still has XP on it so we can't upgrade it. I've ran into that issue with macros written both on 2013 and prior, so I'm not certain if that has much to do with it.
Now and then, a macro won't run but also won't crash SW, and will allow me to open it in the editor. When this happens, there will typically be multiple instances of the same VB project in the editor. When I close the editor SW prompts me to save " ? ". Not certain what that means. Good luck.
