0 Replies Latest reply on May 14, 2013 8:59 AM by jason van clark
    PDMW Check-In - No Valid Client License work-around
    jason van clark
      This may be a non-issue for a lot of folks anymore, but I was still having problems.  The scenario:
      I had written a VB.Net program that would check a file into our workgroup vault.  The O/S is a 64 bit environment.  SolidWorks is 2013, 64 bit version.  As we all know, the vault was throwing the error due to the mismatch in environnents (pdmw is a 32 bit environment).  What to do?
      First off, the strategy.  Essentially what I am doing is saving files in SolidWorks, setting them to read-only, then saving their file location to an Excel file.  Once my list has been completed I automatically kick off an external executable that was programmed and compiled for a 32 bit environment.  The external executable opens the excel file, works its way through the list, checking in each item.  Once the executable completes and closes then the original program reloads each file.  Simple, right?   Yeah........
      So, the code.  Here's the code that builds the excel file.  Note that it is very important that you fully close the excel file through code
      Private Sub updateIDs()
              Dim origFile As String
              Dim tempMod As ModelDoc2
              Dim tempDir As String = "C:\work"
              Dim excelRowCounter As Integer = 2
              Dim excelApp As New excel.Application
              Dim ExcelWbk As excel.Workbook = excelApp.Workbooks.Add()
              Dim ExcelSht As excel.Worksheet = ExcelWbk.Worksheets(1)
              Dim loginInfo As List(Of String) = getLoginInfo()
              Dim excelName As String = tempDir & "\loginList.xlsx"
              Dim openedFileList As New List(Of String)
              If Not My.Computer.FileSystem.DirectoryExists(tempDir) Then
                  My.Computer.FileSystem.CreateDirectory(tempDir)
              tempMod = swApp.ActiveDoc
              origFile = Path.GetFileName(tempMod.GetPathName)
              With ExcelSht
                  .Range("A1").Value = "Original File Name"
                  .Range("B1").Value = "Copied File Name"
                  .Range("C1").Value = "Description"
                  .Range("D1").Value = "User Name"
                  .Range("E1").Value = "Password"
                  .Range("F1").Value = "Successful"
                  .Range("G1").Value = "Status"
                  .Range("H1").Value = "Revision"
              End With
              For Each entry As DictionaryEntry In updateIDList
                  Dim temp As Object
                  temp = entry.Value
                  If openFile(temp(0)) Then
                      Dim swxModel As ModelDoc2
                      swxModel = swApp.ActiveDoc
                      openedFileList.Add(Path.GetFileName(swxModel.GetPathName))
                      Dim docName As String = Path.GetFileName(swxModel.GetPathName)
                      If changeOwnership(docName, True) Then
                          Dim propMan As CustomPropertyManager = swxModel.Extension.CustomPropertyManager("")
                          propMan.Add2("PartID", swCustomInfoType_e.swCustomInfoText, "")
                          propMan.Set("PartID", temp(1))
                          Dim desc As String
                          Dim newFileName As String
                          newFileName = tempDir & "\" & Path.GetFileName(swxModel.GetPathName)
                          desc = propMan.Get("Description")
                          If desc Is Nothing Then
                              desc = ""
                          swxModel.SaveSilent()
                          swxModel.SetReadOnlyState(True)
                          'My.Computer.FileSystem.CopyFile(swxModel.GetPathName, newFileName)
                          With ExcelSht
                              .Range("A" & excelRowCounter).Value = swxModel.GetPathName
                              .Range("B" & excelRowCounter).Value = newFileName
                              .Range("C" & excelRowCounter).Value = desc
                              .Range("D" & excelRowCounter).Value = loginInfo(0)
                              .Range("E" & excelRowCounter).Value = loginInfo(1)
                          End With
                          excelRowCounter = excelRowCounter + 1
                      If origFile <> docName AndAlso Not docAlreadyOpen Then
                          swApp.CloseDoc(docName)
                          swApp.ActivateDoc(origFile)
              Next
              ExcelSht.SaveAs(excelName)
              ExcelWbk.Close()
              GC.Collect()
              GC.WaitForPendingFinalizers()
              GC.Collect()
              Marshal.ReleaseComObject(ExcelSht)
              Marshal.ReleaseComObject(ExcelWbk)
              Marshal.FinalReleaseComObject(ExcelSht)
              Marshal.FinalReleaseComObject(ExcelWbk)
              excelApp.Quit()
              Marshal.FinalReleaseComObject(excelApp)
              Dim processID As Integer
              Dim proc As System.Diagnostics.Process
              processID = Process.Start("C:\SolidWorks Data\TDS\Add-Ins\TDS AddIn Manager\Buttons\checkInExecutible.exe").Id
              proc = Process.GetProcessById(processID)
              Do While Not proc.HasExited
                  Thread.Sleep(1000)
                  'ProgressBar1.Value = ProgressBar1.Value + 10
              Loop
              reloadDocs(origFile)
              Me.BringToFront()
      ____________________________________________________________________________________________________
      And here's the code in the executible (Note: must be compiled to an x86 environment only!!)
      Imports PDMWorks
      Imports System.IO
      Imports Microsoft.Office.Interop
      Imports System.Runtime.InteropServices
      Module Module1
          Sub Main()
              Dim connection As New PDMWConnection
              Dim excelName As String = "C:\work\loginList.xlsx"
              Dim excelApp As New Excel.Application
              excelApp.Visible = False
              Dim ExcelWbk As Excel.Workbook = excelApp.Workbooks.Open(excelName)
              Dim ExcelSht As Excel.Worksheet = ExcelWbk.Worksheets(1)
              Dim excelRng As Excel.Range
              Dim lastRow As Integer = ExcelSht.UsedRange.Rows.Count
              Dim userName As String = ExcelSht.Range("D2").Value.ToString
              Dim password As String = ExcelSht.Range("E2").Value.ToString
              Dim partCount As Integer
              Dim assyCount As Integer
              For j = 2 To lastRow
                  Dim ext As String = Path.GetExtension(ExcelSht.Range("A" & j).Value.ToString)
                  If ext = ".sldprt" Then
                      partCount = partCount + 1
                  Else
                      assyCount = assyCount + 1
              Next
              For k = 0 To 1
                  Dim partInstCount As Integer = 0
                  Dim assyInstCount As Integer = 0
                  For i = 2 To lastRow
                      Dim docPath As String = ExcelSht.Range("A" & i).Value.ToString
                      Dim extension As String = Path.GetExtension(docPath)
                      Select Case k
                          Case 0
                              If extension = ".sldprt" Then
                                  partInstCount = partInstCount + 1
                                  Console.WriteLine("Checking in part file " & partInstCount.ToString & " of " & partCount.ToString)
                                  Continue For
                              Else
                                  GoTo continuethisloop
                          Case 1
                              If extension = ".sldasm" Then
                                  assyInstCount = assyInstCount + 1
                                  Console.WriteLine("Checking in assembly file " & assyInstCount.ToString & " of " & assyCount.ToString)
                                  Continue For
                              Else
                      End Select
                      'Console.WriteLine("Checking in file " & (i - 1).ToString & "of " & (lastRow - 1).ToString)
                      Dim doc As PDMWDocument = Nothing
                      Dim docName As String = Path.GetFileName(docPath)
                      Dim description As String = Convert.ToString(ExcelSht.Range("C" & i).Value)
                      Dim status As String = ""
                      Dim project As String = ""
                      Dim revision As String = ""
                      Dim number As String = ""
                      Dim references As Object = Nothing
                      'connection = CreateObject("pdmworks.Ipdmwconnection")
                      connection.Login(userName, password, "tds-ninjitsu")
                      If connection IsNot Nothing Then
                          doc = connection.GetSpecificDocument(docName)
                          If doc Is Nothing Then
                              connection.Logout()
                              connection.Login(userName, password, "tds-roku")
                      If doc IsNot Nothing AndAlso doc.Owner = userName Then
                          Dim newDoc As PDMWDocument
                          project = doc.project
                          status = doc.GetStatus
                          number = Path.GetFileNameWithoutExtension(docName)
                          newDoc = connection.CheckIn(docPath, project, number, description, "", PDMWRevisionOptionType.Default, revision, status, False, references)
                          If newDoc IsNot Nothing Then
                              ExcelSht.Range("F" & i).Value = "True"
                          Else
                              ExcelSht.Range("F" & i).Value = "False"
                      Else
                      Exit Sub
                          connection.Logout()
      continuethisloop: Next
              Next
              ExcelWbk.Save()
              ExcelWbk.Close()
              GC.Collect()
              GC.Collect()
              excelApp.Quit()
      End Module
      And finally, the update code
      Private Sub reloadDocs(ByVal origFile As String)
              Dim ExcelWbk As excel.Workbook = excelApp.Workbooks.Open(excelName)
                  If Path.GetExtension(ExcelSht.Range("A" & i).Value) = ".sldprt" AndAlso ExcelSht.Range("F" & i).Value = "True" Then
                      If openFile(, ExcelSht.Range("A" & i).Value) Then
                          Dim tempMod2 As ModelDoc2
                          tempMod2 = swApp.ActiveDoc
                          tempMod2.ReloadOrReplace(True, tempMod2.GetPathName, True)
                          If origFile <> Path.GetFileName(tempMod2.GetPathName) AndAlso Not docAlreadyOpen Then
                              swApp.CloseDoc(Path.GetFileName(tempMod2.GetPathName))
              Next
                  If Path.GetExtension(ExcelSht.Range("A" & i).Value) = ".sldasm" AndAlso ExcelSht.Range("F" & i).Value = "True" Then
              Next
              ExcelWbk.Close()
              GC.Collect()
              GC.Collect()
              excelApp.Quit()
      So, there you go, it's that easy
      Enjoy!
      Jason
