Hi there, I'm a final year student working on my major project and I am required to create a fairing that I have designed myself.
The problem is that the fairing I have designed is quite complex, I have fully surfaced it and am happy with the result however I can’t seem to thicken and add material to the model.
I have tried everything spending hours adding to the curvature, there are still errors in the check feature but I really could do with some advice from someone who knows what they are doing.
Thank you for your time,
Jack
Try breaking it up into smaller pieces, and then adding thickness to each section. This will let you narrow down the area/areas that are causing problems.
