Hello;
I have added a a single part with a single configuration to an assy., that has an attached drawing. When I go into the drawing the bom show's the description of the part, but not the part no. I don't think it's the way anything is set, because in a similar one I deleted the bom, & stuck another one in & the part no. showed up. My concern is, when adding a part why should I have to delete the entire bom, & start fresh. When inserting a new one, it can scramble nos., delete typed entres' and a series of other things. I would like it to just show the new item in the bom at the end. Is there a way to do this without, having to delete the bom, & insert another, just because of adding one item?
Thanks, in advance for any input;
Rob_D SW 2013 sp3
Tool-Option-Document Properties
Under Tables - Bill of material - check the box "Automatic update of bom"
Hope this Helps.
