1 Reply Latest reply on May 13, 2013 8:33 AM by Jeff Holliday
    Revision and document control
    Prafulla Dakhole
      whenever i modify the part, do i need to assign revision no or SW will take revision automatically or what is the best practice.....
      kindly help
        • Re: Revision and document control
          Jeff Holliday
          I would  suggest providing more info to us to help us get you an answer.
          Are you using a PDM system or just using a basic Windows file system? The final answer is probably the same - you do not need to change the revision level everytime you work on a file but you may choose to that if the change results in a meaningful design change.
          "Best Practice" can be very elusive and mean different things. If you have a system in-place where you work, "best practice" would mean either following it or making needed changes to the system. If there is no system, I would suggest "best practice" means establishing a formal system and using it.
