I am having trouble with checking things into our workgroup PDM vault. Here is a summary of what is happening:
I finish creating a drawing or an assembly and I attempt to check it in to the vault. I edit the custom properties that I want to (ie. description, drafted by, approved by, date approved, etc.) for both the drawing and the associated sldprt file. I click check in and then it gives me the following error:
I don't ever run more than one instance of Solidworks and I have had this issue both when the associated part was open and when it was not open.
I tried deleting Solidworks completely and re-installing and then restoring my settings files (without and with system options).
I even completely re-installed Solidworks and didn't restore my settings files.
Every time I tried one of the above solutions, Check-in functionality would go back to normal for a couple days but then start giving me this error again.
I contacted our company's reseller and they gave me a work around that I am not happy with. Basically, they said after I check stuff out of the vault I need to move it to a different folder before checking it back into the vault and then it will work. This does work, but I don't understand why I have to do this in the first place because I shouldn't have to.
Also, this does not happen when I check-in the part first, only a drawing or assembly.
I even tried disabling the "Search file locations for external refrerences" box in the System Options->External References section.
Has anyone ever come across this before or know what is going on?
Pat,
For some reason your post just showed up for me to read, even though I have been reading the posts in this forum every day. (About a half dozen other posts in this forum also showed up today for the first time.)
I've never seen this particular problem before, but that may be because I don't make extensive use of the custom properties.
I assume that you are changing the custom properties in both the part file and the drawing file. Is that correct?
Since it seems to work OK to check in the part, then check in drawing or assembly, it seems like an easier work-around would be to check in any revised parts first, then separately check in the assembly or drawing. I don't really understand why moving the files to a different folder helps.
Jerry S.
