4 Replies Latest reply on May 13, 2013 1:27 PM by Trevor Wunn
    SUPPRESS PART IN ASSEMBLY VIA API
    Trevor Wunn
      Good Friday to you all!
      I have a macro that should suppress all hardware(we name them with a 5 number) but for some reason it just isnt suppressing them. Anything you can tell me will be helpful.
      Ive included my code for perusing.
      Trevor
      Option Explicit
      Dim boolStatus As Boolean
      Dim feat As Object
      Dim featureName As String
      Const SWDOCPART = 1
      Const SWDOCASSEMBLY = 2
      Const SWDOCDRAWING = 3
      Dim vConfigName As Variant
      Dim sConfigName As String
      Dim i As Long
      Dim swConfig As SldWorks.Configuration
      Dim swSubFeat As SldWorks.Feature
      Dim subFeatName As String
          Set swModel = swApp.ActiveDoc
          Dim configMgr As ConfigurationManager
          Dim C1a As Configuration
          Dim selMgr As SelectionMgr
          Dim res As Variant
          Dim itemNumber As String
          Set selMgr = swModel.SelectionManager
          Set configMgr = swModel.ConfigurationManager
          swModel.ShowConfiguration2 ("Default")
      'New code to find configuration names
          Set swConfig = swModel.GetActiveConfiguration
          vConfigName = swModel.GetConfigurationNames
          For i = 0 To UBound(vConfigName)
              sConfigName = vConfigName(i)
              Set swConfig = swModel.GetConfigurationByName(sConfigName)
              If sConfigName = "Default" Then
              ElseIf sConfigName = "NO HARDWARE" Then
                  'make flat pattern active configuration
                  swModel.ShowConfiguration2 ("NO HARDWARE")
                  Set feat = swModel.FirstFeature
                  Do While Not feat Is Nothing
                  Let featureName = feat.Name
                  itemNumber = Left(featureName, 1)
                  If itemNumber = "5" Then
                      res = swModel.SelectByID(featureName, "BODYFEATURE", 0, 0, 0)
                      res = swModel.EditSuppress()
                      Set swSubFeat = feat.GetFirstSubFeature
                          While Not swSubFeat Is Nothing
                              Let subFeatName = swSubFeat.Name
                              res = swModel.SelectByID(subFeatName, "BODYFEATURE", 0, 0, 0)
                              Set swSubFeat = swSubFeat.GetNextSubFeature
                          Wend
                  Else
                  Set feat = feat.GetNextFeature()
                  Loop
                  'set back to the correct configuration
              End
          Next
      'End new code
          'create flat pattern configuration
          configMgr.AddConfiguration "NO HARDWARE", "NO HARDWARE", "Alternate Name", 1, "Default", "no description"
              res = swModel.EditUnsuppress()
                  Wend
              Else
          Loop
