Is there a way to check how many drawings or solids are in the vault
if you right click on a project in the vault and select "reporting" it will tell you how many are in the project. I suspect the same thing would happen if you right-click the top of vault list and do the same. I tried but it was taking too long.
That does not show the item count. I could not find any place that gives you totals
The total number of items are shown at the bottom of the report. To filter drawings, change the file type before starting the report.
Is there a way to get the total of everything in the vault not the project total
If you choose the top level in the vault structure, "reporting" should give that toal info.
